Old 01-16-2010, 07:02 PM   #1 (permalink)
moonmonkey
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
echo bellypan install with pics and template
here is my front bellypan for my 2002 echo. it took around 4 hours kind of leisurely working. i used a hacksaw blade a razor knife and regular handtools. it is 4 mm coroplast from a plastic supplyer "Farco plastics" in jax florida. it is thru bolted in around 8 spots,. i think you can read the measurements from the photos i hope. any body with an echo or xb can probably use the measurements.total cost $14.00 middle and rear coming soon.
ID:	5364   Click image for larger version
ID:	5365   Click image for larger version
ID:	5366   Click image for larger version
ID:	5367   Click image for larger version
ID:	5369   Click image for larger version
ID:	5370   Click image for larger version
ID:	5371   Click image for larger version
ID:	5372   Click image for larger version
ID:	5374   Click image for larger version
ID:	5375   Click image for larger version
The Following User Says Thank You to moonmonkey For This Useful Post:
alohaspirit (01-16-2010)
