that grill is huge,, i guess its only got 1 big one, instead of the more modern upper and lower. hope you have a good temp gauge or scangage to watch temps. since most of your cooling comes thru the one big opening are you going to do all the way accross at top /bottom ,or leave a gap in the middle.id do it with something cheap like cardboard/garbage bag/ducttape until i found out how much i could permanatly cover, then clear lexan,or paint it if you want. but you should see a noticeable difference with that huge hole partialy blocked.
