Old 01-17-2010, 09:49 PM   #25 (permalink)
Tygen1
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Seems it may take some time for this saga to play out... It was warm this weekend so I took some time to replace a dead engine block heater and figured that while I had the coolant drained I would put the extra heater core in. The placement was very difficult because some AC lines are right in the way, so I just stuck it down in a cavity and blocked off the top with some cardboard with a dryer duct on the end of the intake snorkle routed thru the cardboard. I don't think there is enough air moving thru the heater core because the IAT is only 15 to 20 degrees higher than ambient, or the same as underhood temps...hmm. I beleive this will really need a sealed system to get some heat transfer, Otherwise it is in and working. It was a pain to get the air out of the coolling system with the extra heater core.
ID:	5381   Click image for larger version
ID:	5382   Click image for larger version
