Old 01-17-2010, 10:21 PM   #22 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Mounting points - make them flexible. If the tire softens, it can push the pan away from the hard mounting points, giving you more time to react before it starts grooving the tire sidewall.
For instance, you could mount the plate on springs instead of standoffs holding it away from the wheel, so that when you put pressure against one side, it would collapse the spring on the other side.
