Old 01-17-2010, 11:58 PM   #4 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
I will only mention that the flow increases may or may not have occurred at a flow rate similar to that which you will see in normal operating circumstances.
I will also note that vacuum flow is much different than flow under pressure inside a tube.
