Old 01-18-2010, 11:04 PM   #10 (permalink)
moonmonkey
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
submitted for your approval (rod serling) echo shapes
thanks for all the help chazinmt and cfg83, i was able to make it work ,i was trying to use too big of a file like you said cfg ,and i used your artwork chaz, i have adobe illustrator but am not that good at anything computer software wise, which is weird because i am an electronics tech for 30 years now. I ran the program with the two different shapes one original and one with a strait back rear decklid , it looks like if you run it back far enough for the air stream to hit it ,it will have the desired effect of only presenting the area under the decklid for drag,,, i think, here are the shapes i used.thoughts?
ID:	5408   Click image for larger version
