Old 01-18-2010, 10:53 PM   #364 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by vpoppv View Post
The first conversion I did I rinsed the daylights out of the battery before adding the alum. Since then, I have read that doing so reduces the performance of the battery. The theory is that the lead sulfate is what is needed for the alum to work properly; so the more "sludge" left, the better the alum battery will work. That's why with this one, I just did a quick rinse and removed as little of the sludge as I could.
As an update: I discharged it for a while with a bilge blower until it was at 8v or so. Then, I put it on the charger. It charged for under an hour. I allowed the charge to burn off or whatever it's called (surface charge??), and it is showing 12.36v. I'm anxious to see the reading after tomorrow's commute!!
Keep your fingers crossed!
Cool! I read somewhere also that you should not completely rinse out batteries when refurb'ing them, but I wasn't sure if the Alum would react with it negatively.
I have drained electrolyte and boiled it off to get the sulfuric, though... My Father was apparently told at some point that you can't replace the electrolyte in a battery...
