Old 01-19-2010, 07:13 AM   #19 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Drl
Jyden, there is an EU directive allowing the use of Daytime Running Lights (DRL). If you have these, then you don't need your other lights (side, cockpit, and registration plate lights). The ones I installed are 5.5W each, so when it's light outside I use only 11W, instead of about 200W.
Of course, when it gets dark I need all of the lights. I've replaced my front position lights (2x5W) with LEDs and rear turn signals (2x21W) with multiLED bulbs. The latter makes the turn signal flash faster, since the lower current makes the relay think a bulb is out. Each bulb in my car has a different socket, so I'm always on the lookout for LEDs that will fit the lights I still haven't replaced. My third stop wasn't an LED, had normal bulbs (4x5W), but the new roof extension blocked it, so I disconnected it and added an LED stop mounted lower.
Originally Posted by Jyden View Post
Somehow I find that the car dosen't freewheel too good. Either the winter tires give a lot of resistance, or there's something else wrong.
When you go for a tune-up, or when you go to change your tires, check the alignment of the wheels. Maybe ask them to straighten them slightly more.
Air mass censor end temperature sensor I cleaned with an artists bruch with VERY soft animal hair dipped in pure alcohol (Isopropyl alcohol). I did this repeately until there was no more dirt.
I did this repeatedly until there was no more alcohol, and my vision got blurry.
