Old 01-19-2010, 06:20 PM   #7 (permalink)
rgathright
Black Beauty - '09 Honda Accord EX-L
90 day: 27.44 mpg (US)
Originally Posted by wfairley View Post
* independent solar collectors covering every horizontal surface, with auxiliary extending surfaces aerodynamically integrated with the exterior
Woody
I tested this concept by using 1sqft of PowerFilm on my Jeep and drove with it for 1 year. The problem was that the solar cell crumbled in the high heat and humidity of Louisiana. The 1 sqft solar cell, when in full sun, could power an 80MM x 80 MM x 10 MM computer fan mounted on the dashboard. You are just not going to get the power you want from an install on a car like this.
Instead, I decided to mount solar panels on my home. The panels will be in a fixed position so I can protect them a lot better than on my car.
Good luck!
