Old 01-19-2010, 07:02 PM   #1 (permalink)
Rainh2o
Ecomodder in Training
Rainh2o's Avatar
Green Machine - '96 Ford Contour GL
90 day: 34.9 mpg (US)
Killing individual cylinder ignition
I did a search on the website but I wasn't able to come up with exactly what I am thinking here. Found all sorts of posts talking about removing cyld and such but thats not what I am thinking. Sorry if this has been discussed before.
I know some of the larger V-8's kill cylinders when in cruising mode to improve mpg. I know they do it with the valve train and computer combination.
What I am thinking is killing only the injectors to 2 of the cylinders (out of 4). Now I know it will probably upset the oxygen sensors so I would also have to take a reading of the sensors in normal running mode and maybe also switch in some sort of voltage source or resistor in place of the oxygen sensors, maybe only the #2 sensor since it would see the most increase in oxygen. Maybe this would trick the ecm that nothing is different and not to dump more fuel into the remaining 2 cylds?
Sounds too easy. What Am I missing here?
