Thread: Longer Stroke?
Old 01-20-2010, 12:33 PM   #12 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
The roller valve train is a popular mod for reducing friction, it certainly wouldn't hurt mileage iether. Piston and head ceramic and friction reducing coatings seem like a good idea for a high output engine. Helps control heat issues. They have DIY products these days so the cost may not be too bad. I'd try it if I was rebuilding.
Be sure to play with cam timing. I advanced my Ford 2.3 OHC cam 9* and got a very noticeable boost in low-end torque. Easy and relatively cheap. Shortly after, I went to bigger and heavier wheels/tires so I can't isolate the cam timing change mileage effects.
Good design is simple. Getting there isn't.
