Old 01-21-2010, 03:20 AM   #4 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
you want to use batteries that are all the same size and age because as you draw them down you don't want one in the string to be at a higher voltage as it has to go thru the other batteries, if they were all parallel then it would not matter as much but if it was a string in series then it matters as it can have the same affect as hooking a charger up to the dead battery backwards.
