Originally Posted by dcb
That looks right
Also note that I think it would be simplest to just solder a phone cord "pigtail" to the guino that is long enough to reach that jack installed under the dash somewhere, where it could still be unplugged if needed.
FYI, I'm considering moving to a pigtail arrangement just because A. these plugs are a pita to make by hand, and B. having a phone jack on the board will make the unit noticeably larger.
The little blue baggie with the second plastic hub and the plugs is missing.
I left it on the counter with everything else but now I can't find it so I'm jut going to run the phone jack wires straight into the Guino.
Pics of progress, all ready to solder as soon as I cut another hole in the enclosure for the phone jack.
