Originally Posted by ahab13
On my 91 Geo Storm 2 of the fuel injectors simultaneously went out, and even with the ECM in limp mode and the unnecessary drag of 2 useless pistons and everything I was still able to drive home about 25 miles using going about 50 on the freeway and almost stopping when going up hills. The Storm has speed density EFI so it goes off of RPM and TPS, and MAF which could be tricky with 2 cylinders. I'm not too sure about tricking it, but If you can figure that out then you should have a 800cc fuel sipper. If not you can just throw the carb on there, and still get really good mileage.
Thanks for this post, and informative for a first post here. There is a thread on going about this
over here, please add your input there, as well!
Welcome to EM!
