The deed is done! Except for calibaration.
I present my 1991 Acura Legend to hooked up to an
MPGuino!
It's getting power. My first real 'wiring job', (aka unacceptably sloppy) it was simply tap a +12v, VSS, Injector, and then ground the fourth wire. Easier said than done with the carpet and the steel plate in the way, but everything's as back to normal as I can make it.
The housing...:hide: Form follows function, and it holds and protects the Guino.
Wiring reference:
Here's more photos I took:
![](http://i126.photobucket.com/albums/p101/SqurielLord/DSCN7228.jpg)
That must be some type of GPS, right? Let's steal it!
-Squriellord.
