Originally Posted by fatman57
from what has been said so far the best system might be a form of water cooled EGR, so you let the warm gasses in, and since this is the stuff doing the warming it should warm the coolant up just as quickly.
If we want to catch more heat from the exhaust and put it back into the engine, then why cool the EGR? Just leaving it warm would be more efficient than transfering the heat to the coolant, which may lose some heat before it returns to the engine block. Also, I doubt there is enough flow in EGR to make much of a difference, since EGR is only a small part of all exhaust flow. Daox has a project going with
cooled EGR.
sorry for the long post.
Don't worry, we see much longer posts here. As long as it has relevant info and/or good ideas it's OK
What matters is
where you're going, not
how fast.
