Old 01-22-2010, 06:53 PM   #82 (permalink)
user removed
Q. MECH, assume you are operating a vehicle at a constant speed and load, with an ICE that has a 98% efficient transmission that is cheap and lightweight, and the engine is operating at bsfc. Lets assume a fairly clean design and the engine only needs to put out 15hp to cruise @55 mph.
It isn't directly relevant to the question, but this is where the bar for peak parallel/direct drive efficiency is at and these are not part of the variables for this question.
Can you give accurate assessments of how converting this relatively constant speed/load operation to a hydraulic will affect:
1. efficiency, in terms of how much power leaving the engine shaft gets to the wheels.
2. weight at the efficiency.
3. cost that weight/efficiency
4. additional space needed in cubic feet to house the components at that weight/cost/efficiency/no word games/ etc.
Also I would say the assume you have a hydraulic transformer in there (you neglected to mention its efficiency) if you wish to also claim the benefits of having a hydraulic system, but I don't care about storage right now, we will come to that, but it isn't a factor in extended constant load/speed operation.[/QUOTE]
Your example is a vehicle that requires 15 HP to maintain 55 MPH with 2% losses through the transmission, and the engine is operating at max BSFC.
Not sure any vehicle exists that meets that criteria, especially with 2% losses from engine to the tires, which reflects all losses. Maybe your word game?
Theoretical max efficiency for the hh would be 89% of the engine power to the wheels. Same for regeneration.
According to EPA and other sources the best powertrains (engine to tire) are about 85% give or take. In fact their web site quotes 70%.
Their figure is 18.2% of potential energy from engine and 12.6% of that available at the rear wheels, 30% losses, far different from 2%.
Weight at the efficiency. The Innas design is quoted as weight neutral. Mine is weight negative, meaning it would weigh less than what it is replacing. Not knowing the weight of your proposed configuration makes a direct comparison impossible. Best answer I can give you without specifics of your base design.
Same or less would be my rough answer without more details from you.
Cost that weight and efficiency?
In mass volume production on assemble line, half of the cost of the replaced and no longer necessary components.
Less volume than what is eliminated, probably 50% less.
http://www.fueleconomy.gov/FEG/atv.shtml
Show me a 2% loss powertrain, this link is 15 times greater losses than your quote.
regards
Mech
