The cooled EGR in VW TDIs does make a significant difference in warm up time in cold weather.
I'm pretty sure getting the heat transferred to the coolant by a purposely designed heat exchanger and then having the coolant circulated works better than just sending back hot exhaust gases in the combustion chamber. Plus you wouldn't get the same NOX reduction.
