allright, that pic describes something that would be ~87 efficient in a series role as a transmission, but doesn't include hydraulic "gear" ratio changes, which is why you would bother with anything but a chain and sprocket in the first place.
ok, so I haven't seen this exact picture anywhere yet (that's your job), but it sounds like you have for comparisons sake:
an ICE driving a constant volume pump
a high pressure accumulator
a low pressure accumulator
plumbing/hoses of sufficient diameter to not incur pressure drop (the fluid DOES flow in this system despite your previous statement that it doesnt, or else you need to draw a picture)
4 floaty cup glorified bent axis variable displacement motors, one at each wheel.
Is that correct so far?
