Old 01-22-2010, 10:52 PM   #22 (permalink)
Rokeby
Gen II Prianista
Rokeby's Avatar
orange4boy recently posted up on my similar thread at PRIUSchat.
Perhaps my reply has some value for this thread:
Originally Posted by orange4boy View Post
...There is a tiny bit of room under the case but the whole pack would
have to be lifted a bit and some bolt holes elongated for that to work.
Might as well put it under the batteries if possible. Christ from EM has
suggested waterbed heater pads as they have a thermostat and are
thin.
FWIW, here is my list of thinnish heating products most likely to work
either under the whole battery box, or between the box and the HV
battery itself -- some of them are pretty "out there."
Self Adhesive Engine, Oil, Block Pre-Heating Pad
Wolverine Engine Oil Heaters - Products
ClearMirror® : The original fog free bathroom mirror defogger - From $69
Electric Foot of the Bed Warmer - Stops Cold Feet!: CozyWinters
http://www.comfortheat.com/files/product_ffm.pdf
Thermocouples, Coil Heaters, Mica Heater Bands, Ceramic Heaters
The “FuzzyLogic” Logic Temperature Controllers warrant a look, but are
probably prohibitively expensive.
These two items are 12v, so would require a 120vAC to 12vDC transformer.
At any rate they are too neat not to pass along:
OEM Products, 12 Volt Heating, Carbon Fiber Dual Temp Waterproof Single Pad Seat Heater Kit
This for blowing hot air through the back seat HV battery inlet vent:
Moose Racing UTV Cab Heater - - Motorcycle Superstore
