Old 01-22-2010, 10:45 PM   #93 (permalink)
NeilBlanchard
So, the hydraulic system itself is wonderfully efficient -- but what about the power source? Is it an ICE? If so, is the ICE used only to charge the accumulator, or does it push fluid directly to the wheel motors? Is the ICE run at a constant RPM, or is it variable?
Because, mechanical transmissions are ~90-98% efficient, aren't they?
