Old 01-23-2010, 10:36 PM   #7 (permalink)
puddleglum
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
I also think you need to invest in a scanguage. Electronic throttles can be extremely sensitive. I know mine is. I find that I need to accel. to speed then back off and watch the SG closely to see where to keep the throttle in a sweet spot because I can't tell by feel. It will also help to determine how to use your turbo to an advantage. At light throttle, your high octane gas may not be doing a thing because turbo engines usually have a lower static compression than their NA twin. Do you have a standard or an auto trans.?
