Old 01-24-2010, 08:15 PM   #74 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by racprops View Post
Have you seen the Peak and Hold injector adaptor by JayCar?? They sell a kit that works with their duty cycle reader kit.
RIch
it looks like they use a shunt resistor and an op-amp. Not sure how it gets dialed in. The opto works by the voltage drop across the inector (for negative switched systems).
re: resetting, you must have inherited a cold solder joint or loose wire or something, cuz there is already a diode and several caps on the prebuilt power.
