Old 01-24-2010, 11:42 PM   #13 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by Christ View Post
Sure, you can shut off the fuel, as long as you do it with an electronic solenoid that closes the main jet in the bowl. (Manual works, too). Otherwise, your engine will keep running until the bowl is empty, which isn't good, either.
The Honda civic carburator has fuel cut off that turns the fuel off when you kill the engine, it does this with 4 valves on the carburator, it also does this when you engine brake, as in when you are going down the hill and take your foot off the gas.
This is why the carburator on the civic is so impressive, of course if you remove any of the 54 vacuum hoses it will stop working correctly and cause horrible engine damage like you are talking about.
