Old 01-25-2010, 12:05 AM   #14 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Ryland View Post
The Honda civic carburator has fuel cut off that turns the fuel off when you kill the engine, it does this with 4 valves on the carburator, it also does this when you engine brake, as in when you are going down the hill and take your foot off the gas.
This is why the carburator on the civic is so impressive, of course if you remove any of the 54 vacuum hoses it will stop working correctly and cause horrible engine damage like you are talking about.
This must be something I wasn't made aware of during my time with Honda engines. Do you have a reference for this that I can read?
Still, I imagine that if his carb was working properly to begin with (if his were as you describe), it wouldn't have been dumping fuel after shutting the engine off, so the issue would have been negated altogether.
