still trying to figure that out. Can you measure the injector ohmage too?
here are the defaults FYI
Code:
unsigned long parms[]={55ul,8208ul,500000000ul,3ul,420000000ul,10300ul,500ul,2400ul,0ul,2ul,0ul};//default values
char * parmLabels[]={"Contrast","VSS Pulses/Mile", "MicroSec/Gallon","Pulses/2 revs","Timout(microSec)","Tank Gal * 1000","Injector DelayuS","Weight (lbs)","Scratchpad(odo?)","VSS Delay ms","InjTrg 0-Dn 1-Up"};
