Old 01-25-2010, 12:20 PM   #24 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Jyden View Post
Injection systems are complicated. Changing one thing will cause the ECU to change a lot of oter things.
As to undertand how theese things work - at least in some Toyota applications, this is a good read.
http://www.autoshop101.com/forms/h25.pdf
(Pls note the role of the oxygen sensor)
Injection systems are complicated, yes. Their ultimate goal is to run the engine inside of pre-determined parameters. How they go about it is of no consequence to us, as long as the end result is the same.
