Originally Posted by RobertSmalls
My lean-burning Honda calls for a different method, but in the Subaru, I accelerated slowly at 75% throttle at low RPM. You use RPM to modulate the rate of acceleration, and keep it low for maximum efficiency. It's an entertaining way to drive, because it requires skilled feet. You also have to plan ahead, because if you want more power, you're going to have to use your right hand, or wait for revs to rise.
Unless your electronics tell you otherwise, I assume that you mean the pedal is 3/4 of the way to the floor? I'm not sure, however, how you accelerate slowly with a 75% throttle opening. I've been driving lately barely touching the gas. But there's no doubt, that would require some skilled feet!
