Old 01-26-2010, 08:18 AM   #80 (permalink)
Superturnier
My way is the low way
Superturnier's Avatar
MyoldFord - '65 Ford Taunus 20M Turnier
90 day: 27.59 mpg (US)
Plastic Spaceship - '94 Renault Espace
90 day: 24.03 mpg (US)
Sussu - '82 Suzuki Alto
I think I have peak and hold injectors also.
After reading this topic I realized that I have similar symptons that someone mentioned earlier. My MPGuino reacts primarly to gear changes. Pressing the gas pedal does not have much affect. Also I have the low ohm injectors.
So I measured the injector signal with a scope and it seems that I have a problem to solve. The hold part in the picture is somekind of pwm signal which should be counted also to the injector open time.
My first thought was to make a high pass filter which averages the short pikes in the signal. I think that the injector pintle cannot follow the short pikes either.
Name:	injector signal.JPG
