Adam,
I would like to see a way of defining a set of variables that could be used to program the controller's variables in a 'one button' approach.
I.e. User defines a 'button' with the title "Valet Mode" and sets throttle response to a particular low value, sets max amps to a specified low value, and any other appropriate controller variable.
Similarly, a 'button' that would have a title of "Normal" would set the variables to what you think 'Normal' means.
Then a 'button' that could be labeled "Hot Rod".....
Then display these 'buttons' in another window for easy choosing.
This would require the RTD to have some knowledge of limits for each variable in combination with the others for error and warning conditions.
This would basically be a 'one button' setting of the 'general characteristics' of the controller.
Eric
1995 BMW 318i EV in the making
