Belly pan soon
I was able to pull the back off a shelve at work today that they where getting rid of because they say its junk I say It has potential. So what i found was a 6'x8' 20 ga sheet of stainless steel. It has some small holes in it where it was bolted the shelve but I could cover them with duck tape or caulked them close. I will try they bell pan this weekend due to the honey do list is long.
I'm also thinking about making a small scoop under the car so to pull air in to the radiator because I have the front damed off. If I open the front the air will have know where to leave the engine bay due to the belly pan. So a small scoop maybe sticking down an inch buy 3 inhes wide like a small wedge would push air right on the radiator. Any thoughts?
-Matt
