Old 01-26-2010, 04:30 PM   #20 (permalink)
bobert5064
RTD Explorer Architect
Send a message via AIM to bobert5064
That's a pretty good question. The program requires the .net framework which is available for Windows 98, but the only reference I can find for it is 1.1, which is not high enough to run RTD Explorer. So at this point I would say that it is likely not possible. As I said in some of the other posts we do plan on porting it to Mono at some point so that it can be run on Linux which should run really well on older hardware. If that is an option for you then I would highly suggest that when we make the change!
Good luck!
--Kyle
