Hey Paul, I'm not sure how close the charging curve is. I think I can get a pretty good idea of how it works if I discharge a set then use the usb hookup to plot out volts and amps while it charges. If that works then I might try the same thing with some AA nimh bats I have around. I also have some lead acids but those have a really simple charge curve. If I get my hands on some lifepo4s from a drill pack I can plot those too, I don't know if the big EV ones charge differently other than the C rating which I'd assume would be bigger.
