Had this crazy idea...since I have a T-100 truck. Instead of just trying to put on a wheel skirt...make it fer the entire lower side of the truck. It will probably make it look some some armor on the side...
It will have support on the bottom so it doesn't move horizontally and back into the rear tire. It will be pushed out a little on the bottom edge to clear the rear tire. There will be a wedge up front to keep air from gitting in between the body and the panel. It will probably only be installed fer long runs on the road instead of local drives. I want to use some material like the R-Matte I used fer the side skirts...
Here's the area it would cover...
Yer thoughts?
