BamZipPow -
Me likey how you thinky. I think I have the same option, starting from the rear wheel well, if I choose to implement it :
Originally Posted by cfg83
Cutting out the middle is based on jthistle's idea of using a wheel flare as a "base" for a wheel skirt :
http://ecomodder.com/forum/showthrea...kirt-4504.html
However, I think the drain pan is a better "base" for mounting wheel skirts because you don't have to deal with the "curve" of the fender flare (hard to describe). You just have to mount the cover on a uniform "flat" surface. If I was more bold, I would make a cover for mine that looks something like this outline :
CarloSW2
