it might give you a sharp rear edge for clean seperation ? try it and see! aero is not always going to act like you think it will .do you have a belly pan? that helped me, also do you have any results from your skirts, and how wide are the skirts,are they one narrow peice or as wide as the tires? basjoos aero civic has both an inner and outer side skirts the width of his tires,i think. hard to argue with his results
