I think you better check outside to see if people are starting to line up outside your front door (even in the snow) for these boards!!
Very exciting compliments to the Cougar design.
Great work.
Eric
Originally Posted by adamj12b
On this board, I will be including the precharge circuity, bus voltage measurement circuitry, and I was thinking a tach pulse input from motor with a tach pulse output to drive an in-vehicle tach with software scaling so that it will display the right RPM. What do you think?
-Adam
