Old 01-29-2010, 12:18 PM   #36 (permalink)
jfitzpat
Originally Posted by Old Mechanic View Post
In my VX lean burn stops at 2500 RPM, so I try to use lean burn almost exclusively. I can feel the power surge when I go beyond the lean burn threshold with throttle position, so in this case it is well below 80%, but that is just becasue of the lean burn feature of the VX. The VX pulls well enough from 1000 RPM in 5th gear at 30 MPH.
Is your Honda using the older CVCC system? I mean, does it use the parallel fuel path? I've read about them, but never driven one (that I can recall). But I've looked at the newer Honda lean burn system quite a lot and the transition is very subtle. I'm not sure I would be able to to detect it by feel.
-jjf
