Originally Posted by sawickm
Why are you connecting your expanded I/O PCB into the ISP port? Is the ATMEGA8 I/O maxed out ??? Is there another compatible ATMEGA that has more I/O ?
Good job,
-Mark
Probably because the pins not used aren't pulled out to a connector, the ISP port is available in the boards already made... The next version should really bring any and all unused ports to a connector...
