Old 01-30-2010, 09:17 AM   #10 (permalink)
ATaylorRacing
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
I'd suggest going to some 155x80x13 tires on American Racing Estrella rims. I went from that size 13 to the 195x50x15 tire/rim package on my Geo Metro 3 banger and the tire/rim pacage is 8 lbs heavier per corner. The old tires had a max tire pressure of 35 while the new ones would take 51. In the end the gas mileage on flat ground/highway speeds remained the same due to much less rolling resistance, BUT the 1/4 mile times went from 19.9s normally to 20.6s. When the weather gets warmer I will return to the 13 set up. The Power Star 13" tires are 14 lbs while my Estrellas in 15" are 18 lbs. My 15 inch rims are 16 lbs while the Am Racing 13s are 12.8...BUT, the newer 13s can take more tire pressure than my old ones. Going back to my 1/4 mile ets, I did take an extra 32 lbs out of the car to make the wt the same as it was earlier with the 13s. When I go back to the 13s I will loose anoth 32 lbs so that my new wt will be 1598 compared to the present 1630. I have taken 132 lbs out of it, but added 32.
Another idea I was thinking about was to keep my 15s, but go to the 175x55x15 size that are 4 lbs lighter and less costly than a new tire AND rim set up!
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
