Old 01-30-2010, 11:45 AM   #99 (permalink)
AaronD
Originally Posted by janvos39 View Post
The weight for the balancing is added and I noticed no different vibrations. I leave it like this. Reducing the weight brings no big advantage at low revs.
I thought reducing rotating mass in the engine might have a meaningful benefit. I've heard of lightweight pistons, but admit that I didn't know why they'd be used.
On the CVT. I enjoy the characteristique during acceleration. Even with a high gear (starting in second in my case) acceleration is very well.
If you look at the efficiency of the CVT that is lower than manual transmission.
Info from various sources give efficiency of around 85 percent. Where manual transmission is between 95 and 98 percent. So probably a difference of 10 % in FE can be expected.
Somewhere in the future I will test that.
I've seen similar numbers for CVT vs Manual Transmission efficiencies, but it seems they are all measuring JUST the efficiency of the transmission itself. Since the CVT keeps the engine closer to an optimal RMP range though, there should be some gain in engine efficiency over an average driving cycle when using a CVT vs Manual (depending on when you shift perhaps). So it would be interesting to see what the efficiency is when including both engine AND transmission, instead of just the transmission.
Aaron...
