I'd like to take Bondo's hatch top a step further.
Instead of a hatch use a tambor-type tonnea as the cargo cover. I like the ReTrax topper but there are others. Get one that is four feet wide (for a step-side truck and install it on an appropriate slope. Put a filler plate on the tail gate. This type rolls up into a canister in the front and allows access in a matter of seconds.
No free lunch. The canister takes up about eightenn inches of bed space.
Mated to Bondo's well-made fiberglass, it should look spectacular and work well enough for most people.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
