The first time I did a project like that ( and every project since) I took a lot of pictures and video of what I was doing and where everything went, as well as marking everything with masking tape and a sharpie. If you are anything like me, it's way to easy to get confused by all the hoses when what they do isn't obvious. The one from the filter feeds the fuel to the carb, and beyond that you better have a good idea of where everything went before. It takes a lot of time to mark everything like that, but it sucks when you hook something up wrong and it doesn't work, and you can't find an expert when you need one to say, "Well this one goes here, and that one goes there, and presto..." A book may or may not help you in that case. Good luck!
