Old 01-30-2010, 04:01 PM   #19 (permalink)
Mifunego
Mifunego's Avatar
The Taco - '99 Toyota Tacoma Prerunner
90 day: 19.29 mpg (US)
Originally Posted by RobertSmalls View Post
The engine by itself would be most efficient at full throttle, but most ECU's will enrich the mixture once you pass, oh, 3/4 throttle. As to how I accelerate slowly, well, even the 2.2L Subaru with its nice flat torque curve doesn't make much power at 1500-2200RPM. And my 1.0L Honda engine is even better.
How low can you go without lugging the engine? Do that, at full throttle.
Robert,
I'm guessing that this method works best in a non-turbocharged engine. Of course there is a difficulty with opening up the throttle so much without spooling up the turbo and occasionally hitting boost stage. I think my mpg on the most recent tank, trying the above method backs that up, as I have dropped to a 25.13. And while that is still better than EPA, it is not as good as I can get. Whether it is due to the use of the turbo or my application of this method is another question. FWIW, I have also been shutting down at stoplights, when appropriate.
Of course, if the 2.2L you're talking about is force-fed also, then it's probably my technique.
Regarding coasting and shut down, I agree with nj1266 about the potential hazards of turning off the car in traffic. I coast in neutral when I can, although living and driving in a city like Chicago can make that a challenge. I also shut off the car when I know I'll be waiting more than just a moment or two at a stoplight (not well defined I know, but that is a play-it-by-ear type of call). I'm not saying it can't be done, I personally am not comfortable with it.
