Old 01-30-2010, 07:59 PM   #1 (permalink)
moonmonkey
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
mirror delete & reduction with pic's.
just completed phase two of project echo, removed the passenger mirror, and placed one on the inside,took off the factory drivers side and installed two much smaller ones, I never knew what i was'nt seeing with my stock rear view mirror, the panoramic one i put on is awsome, i can see out both rear seat windows and of course the rear window,it just clips on the existing mirror,(spring loaded universal fit) it was $19.99 at discount auto parts. The other mirrors are from o,rileys auto parts $8.49 for the drivers outside and $9.99 for the two on the inside, just shy of $40.00 dollars, reduced frontal area, and i can see better than before.
ID:	5504   Click image for larger version
ID:	5505   Click image for larger version
ID:	5506   Click image for larger version
ID:	5507   Click image for larger version
The Following User Says Thank You to moonmonkey For This Useful Post:
Christ (01-31-2010)
