Now that I'm looking at it more.. I found out that the maximum angle of the diffuser is 25 degrees, which is far sharper than most. However, at slower speeds, I don't think this will make much of a difference. If I needed to, I could just add a few strips of coroplast between the diffuser and bumper as a spacer.
I could also put a smaller piece on the other side, but I'm concerned about the lack of mounting points on the open side. What do you guys think?
