Old 01-31-2010, 11:33 PM   #7 (permalink)
MadisonMPG
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Originally Posted by Christ View Post
Can you weld? You either need to extend the spring pack's alignment pin by an inch, or you need to weld a new alignment pin onto your block and drill the spring side of the block for the pin that's already on the spring pack.
You could also just remove the overload spring, if you don't load your suspension up too much normally.
I can weld, I don't have a welder. How much drop am I looking at if I remove the overload spring? And how much am I looking at losing in carrying capacity? *no I don't load it up often, but I don't want to not be able to put a couple hundred in the back.
