Old 02-01-2010, 02:45 PM   #8 (permalink)
aerohead
2.5 vs 25
Originally Posted by AeroModder View Post
Now that I'm looking at it more.. I found out that the maximum angle of the diffuser is 25 degrees, which is far sharper than most. However, at slower speeds, I don't think this will make much of a difference. If I needed to, I could just add a few strips of coroplast between the diffuser and bumper as a spacer.
I could also put a smaller piece on the other side, but I'm concerned about the lack of mounting points on the open side. What do you guys think?
I believe that would be 2.5-degrees,not 25.The panel can go as steep as 4-degrees,depending on where it begins under the car.It's in Hucho's book.
