Old 02-01-2010, 04:48 PM   #2 (permalink)
MD2000
Master Modifier
MD2000's Avatar
Nice write up.
The same ECM connector B has a ground wire that I use for the FAS system. It is pin 20, A brown/black wire.
The taped ground will probably work for a while until humidity causes the copper and steel to corrode, so when you get a chance, you may want to move the ground.
Photo showing the location:
http://www.99mpg.com/mima/pininstall...ctionsr1.jpg,0
Mike Dabrowski
