Old 02-02-2010, 10:04 AM   #15 (permalink)
tpwalsh
CRX - '91 Honda CRX Si
90 day: 39.53 mpg (US)
I don't know if they switched housings between generations but they definitely made both front and rear diffs in the 97-05? generation.(FIL's truck is a 4x4 and a 3.08). The best way to find a pair(front and rear) for cheap is to go junkyarding. On the drivers door is vehicle certification sticker, on it is an AXLE field. Here is the table you need to find a 3.08.
* 18 — 3.08, non-limited slip, F-150
* 19 — 3.55, non-limited slip, F-150, F-250
* 26 — 3.73, non-limited slip, F-150, F-250
* 27 — 3.31, non-limited slip, F-150, F-250
* 28 — 3.73, non-limited slip, F-150, F-250
* H9 — 3.55, limited slip, F-150, F-250
* B6 — 3.73, limited slip, F-150, F-250
